Just a quick Harmony 655 question
Discussion in 'Home Cinema Control & Remote Controls' started by kevH, Nov 30, 2004.
  1. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    Hi there
    Just a quick question on the Harmony 655.
    Anyone any experience of using the Lintronic Uni2 lamp dimmer with the harmony as the Lintronic doesnt come with a remote you can "learn" from.
    I take it it is though possible to make the Uni2 work with this in some way?
    Kind regards
    kevin
  2. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    If you look on the product page for the Lintronic Uni-2 (www.lintronic.dk) you will find the manual. The manual tells you how to set up the Uni-2 to work with a remote.
    Unusually the Uni-2 learns the code from the remote. You will need to set the Harmony up so that one button fires a code that is not going to be used in the room, then learn that code onto the Uni-2. Either learn a code that comes from a device not in the room or set up a device on the Harmony that you don't have and use any code from that or enter a miscellaneous Pronto code from www.remotecentral.com and use that.
  3. kevH
    kevH
    Oct 11, 2004
    833
    +37
    hi ikki
    only one thing ive got to say to you mate
    "your a bloody genius!"
    whatever job your in your in the wrong one lol
    used the other remote command route an hey presto first time
    missus sends her heart felt best wishes as she says i was getting
    a little grumpy with the remote not working properly (never)
    cheers
    kevin
