Just a little advice please :)
Discussion in 'Desktop & Laptop Computers Forum' started by clubber, Nov 5, 2005.
  1. clubber
    clubber
    Hey guys, i just want to know is it worth me buying a new PC if i want to play games like Battlefield 2 in a decent resolution? or would it be cheaper to upgrade my current PC which is only 1 year old and working fine.
    My current PC :
    CPU : Pentium 4 3.0Ghz
    Motherboard : click me (too much info to copy n paste on the forum)
    Graphics : Video Controller ATI Radeon 9100 IGP
    Ram : 2 sticks of 512mb DDR400
    It also came with a TV Tuner, Big enough hard drive and a big enough flat screen.
    Obviously i'll have to upgrade my graphics card and maybe buy a sound card. Can you guys give me an average price on how much it might cost me to get to play these sort of games?
    Do i have enough RAM?
    Is a P4 3.0GHz powerfull enough?
    Thanks very much.
  2. Rambles
    Rambles
    Jul 14, 2004
    10,541
    167
    UK
    +2,216
    Yes, should be fine with an upgrade. I have a P4 2.66 O/C to 3ghz and a 6800GT, have not played Battlefield, but everything else I have tried runs fine at 1280 x 1024 at max settings.
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,498
    South Derbyshire
    +206
    It will be fine with a gfx card like a 6600\6800.
  4. clubber
    clubber
    Thanks for the info guys but i noticed most of the geforce's are AGP8x, will this work with my mother board?
    EDIT: ok i've found out it will work ok.
    I've also found a GF 6600 for £129.99 :clap:
  5. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    You may need to check your PSU - these powerful gfx cards burn the juice a bit.
    I've read that ATI cards are a bit more power efficient - but that's just what I've read, I can't confirm that to be fact - some googling may be in order.
    That said, it does seem the 6600GT is the best bang for buck around at the moment!
  6. Rambles
    Rambles
    Jul 14, 2004
    10,541
    167
    UK
    +2,216
    I have 6600GT in my HTPC and a 6800GT in my main pc... To play games smoothly with the 6600GT I have to use a lower resolution and turn the settings down to medium. With the 6800GT, I can play at the highest res my monitor supports (1280 x 1024) and put all the settings on max.
    If you can run to it a 6800Gt will give a much better gaming experience.
  7. clubber
    clubber
    Ive just ran a price check for the 6800gt and it seems well out of my price range.
    I'm looking for something around £100 really. I was told a 6600GT would play battlefield on max settings?
    THIS is the one i was thinking of getting. Seems like a good price and this site is also my local computer store.
    Your thoughts?
  8. Shockabuku
    Shockabuku
    Mar 5, 2002
    1,809
    Oxfordshire
    +170
    Here's a Battlefield 2 benchmark comparison of a few graphics cards, including the 6600GT. I've just upgraded from a 9800 Pro to a 7800GT. The new card will run BF2 at pretty much any setting I like. The 9800 Pro was fine at 1024x768 with medium/high detail. The 6600GT should fall in between these two cards, though more at the lower end I would guess. I don't think it'd run BF2 maxed out, but it'll still run fine & look great.
