just a grahics card needed for hd playback?
bearman3784
hi all, not too hot on my pc stuff but just wanted to know is all i need to upgrade is my graphics card to playback hd content from my pc to lcd tv? (pentium 4 2.8 ghz with 1gb (probably 2gb soon) ram) thanks
Zarch
Its not quite as easy as that.
Firstly are we talking AGP or PCI-e? I'd think AGP with the CPU you've got, but i might be wrong.
These "HD" graphics card, ie the ATI 2x00 series only provide you with hardware acceleration when playing back HD-DVD and Blu-Ray original material through PowerDVD ONLY.
Any file based playback (expect true hd-dvd and blu-ray images) will soley use CPU power, so your 2.8ghz P4 will struggle a little. Although with the right codecs in place you 'might' just get away playing 720p wmv and h264 encodes.
See this thread for some performance stats: http://www.avforums.com/forums/showthread.php?t=666171&highlight=codec
And this for codec information:
http://www.avforums.com/forums/showthread.php?t=652538&highlight=codec
Finally going back to the AGP questions. There are reported problems with the AGP versions of the ATI 2x00 versions of the cards where hardware acceleration doesnt work, whereas PCI-e versions work fine.
Check out this thread on avsforum for more details on the ATI 2x00 series of cards: http://www.avsforum.com/avs-vb/showthread.php?t=872538
bearman3784
thanks, is there anyway to tell definately what graphics card i need? (AGP or PCI-e)
Zarch
found out from here http://reviews.cnet.com/desktops/hp-business-dx2000-pentium/4505-3118_7-30793526.html looks like i need a pci card. was thinking the Gecube HD 2400Pro, does this sound ok?
No, looking at your spec, its says your box has got a free PCI slot, not a PCI-e slot. (a very big difference!)
In terms of age, the slots go PCI, AGP and then PCI-e in order.
So looks like you need a hardware upgrade i'm afraid!! You box is pretty old!!
Going back to the card itself i'd got for a 2400XT or 2600Pro, the 2400Pro does struggle with one particular type of file, whereas the other models work flawlessly. So well worth the few extra quid.
