Just A Few Questions
Discussion in 'Home Cinema Buying & Building' started by farshad, Mar 31, 2005.
  1. farshad
    farshad
    Hi Hornydragon
    thanks for your recommends. sounds like good choices ... I will make more research now.
    Would really appreciate if you (or other readers) could comment my other questions.
    Please help me with these questions:
    1)- If this sound system bought in US, is it compatible here in UK or other countries like Spain or Australia?
    2)- What (else) do I need to buy to connect all in 1 system with the panny and sky+? scart board? cables? ...
    3)- Difference between Panasonic TH-37PW7 and Panasonic TH-37PW7B? Originally chose a better Plasma (Pioneer 435) but change mind, as I am moving to another country in 2 yrs (probabely to Australia, Spain or Caribbean ..., don't know yet!)
    4)- Anywhere in London you know I can test these (with or without PW7)?
    Many thanks in advance for any advice
    have a good day
    Farshad
  2. thewul
    thewul
    Oct 1, 2004
    275
    +15
    the states run off a 110 volt system so this could be a problem, you may need a step down transformer
    also the unit will be region 1 and without modification will not play any uk region two discs :mad: it is also worth a mention that while region 2 to multi region conversion is no probs, region 1 to region 2 or multi region is not generaly done in this county and you would find it very difficult to find someone producing the software or hardware to do this
    by a uk unit and it will work in spain as well :)
