Jurrasic Park & Lost World R2
Discussion in 'Movie Forum' started by Jules, Oct 11, 2000.
  1. Jules
    Jules
    Oct 11, 2000
    5,633
    134
    +1,121
    I bought the box set of Jurassic Park and the Lost World R2, and thought you may like to hear what I think of it.
    Well the picture on JP is O.K. though a touch bland and soft in parts. The sound on JP is very disappointing, the LFE channel appears pretty redundant and the overall
    impression is a bit flat and unexciting compared to other films. What a pitty!
    The Lost World has a poor qaulity picture at the start of the film but it gets better later on. The sound is a bit better than JP but not much (there is a better use of the LFE channel). But then again, the Lost World is a poor film overall compared to JP and I would honestly recommend that you save your money and keep the VHS copy.
    I am begining to ask myself why I bought it
    actually.
    Anybody agree/disagree?
  2. PoochJD
    PoochJD
    Aug 28, 2000
    11,001
    Norwich
    +1,861
    Don't bother with the Region 2 version! Get the Region 1 discs, and get a DTS soundtrack, as well as a choice of buying JP and TLW:JP 2 on either: widescreen only DTS discs, pan-&-scan only DTS discs; as a boxed set with both movies, and a luxury boxed set with stuff like scripts, film cels, etc for about £75-£80!
    R2 discs get such shoddy treatment, why bother with them?! Also you'll find the R1 discs cheaper, as long as you don't mind waiting to receive them through the post! For a DTS disc, it's definitely worth the wait!!!
    Pooch
  3. mysteriousjimmy
    mysteriousjimmy
    just picked up my boxed set here in Australia (no dts version either) the R4 version is also zoned R2.
    Checked a few other of my dvd's and alot are zoned both R2 & R4
    Would like to buy R1 discs but with the Aussie $ compared to the US$ I think not
  4. Matt
    Matt
    Jul 13, 2000
    775
    Cambridge
    +19
    That all depends, there have been reports that the dts on JP is not as good as the DD mix. Theories go that JP/LW were the first to use dts and it didnt get a new mix done, whereas the DD is a all new mix.
    If you had ordered this via HMV or Tescos you could have got the JP/LW boxset for 20 quid delivered, somewhat of a bargain price.
