londonbairn
Established Member
Same trick as Star Wars, this is marked down to £25, using £5 off every £20 through O2 Moments, you can get this for £20
There are tonnes of bargains to be had with that voucher, especially on some electrical itemsYou could stack it on 2 for £15 blu-rays to get 6 for £35 for example, and it also brings many new releases in line with online prices for convenience.
Dont you have to spend £20 quid tho and then they give you a £5 voucher so you have to spend £20 first ?
The HMVs I went to took it straight off the total, see my post in the Star Wars thread, http://www.avforums.com/forums/15951449-post8.html
Mensy said:So did you spend over £40 to get the £10 voucher and then used that £10 voucher on another item ?
No, I spent over £20 on my 2 blu's for £15 plus a DVD present for someone else, and they took £5 off the total.
And my missus bought the Fast & Furious boxset for £30 and got £5 off.
They take it off there and then rather than u getting a £5 voucher back![]()
