Jumpy DVD playback on PC!
Discussion in 'Desktop & Laptop Computers Forum' started by unrealrocks, Nov 21, 2003.
  1. unrealrocks
    unrealrocks
    OK - I don't have a DVD player upstairs so I play DVDs on my PC (it has a 21" monitor so is pritty good).
    I've not played a DVD recently although just tryed to watch Charleys Angels : Full Throttle and the picture and sound is really stuttery ... unplayable! Just tryed another DVD I know works in it and sure enough - same problem!
    System is a 2100XP, ASUS A7N8X-D V2.0, Sound is the onboard SoundSTORM, GeForce4 Ti4800SE and an old 8x (Samsung I think) DVD player with Multiregeon flash!
    Anyone else have this problem - anyone know how to sort it because its really annoying me :(
    Cheers!
  2. pinatubo
    pinatubo
    Check the DMA setting for the IDE channel the DVD drive is on.There is a problem with this in Win XP - if the drive encounters read errors then Windows will reduce the DMA setting to PIO mode.Fortunately it straight forward to reset the DMA setting.
    If the drive is stuck in PIO mode then you will need to uninstall the IDE channel and then reboot.THe IDE channel will then be redetected and reinstalled in DMA mode.
    There is an article on this problem on Microsofts site but I can't find the link at the moment.
  3. kelvin
    kelvin
    Apr 22, 2002
    1,544
    Down South... (Bournemouth)
    +45
    Moving to HCPC :) Your question may be better suited to there :)
    K.
  4. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    What DVD player software are you using? Try disabling/enabling hardware video acceleration. Some display driver sets are fussy, one way or the other.
    MuFu.
