Matt Horne
Hi..
Every so often my sky box will output a picture which is jumping..
no matter what channel you go onto. If i turn the box on/off with the remote it goes away.. anyone seen this before.
The only change to the box recently has been using a Russ Andrews Yello power cable over the original one.. Do you think this is causing it ?
MAtt
MAtt
