jumper
Discussion in 'Satellite TV, Sky TV & FreeSat' started by tcgills, Jun 3, 2005.
  1. tcgills
    tcgills
    Dec 26, 2002
    92
    just replacing old disk drive when they say make sure jumper is set to cable select whet and where is th jumper :lease:
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The jumper is normally next to the IDE connector on the back of the drive, and normally has 3 possible positions, "Master" (M), "Slave" (S), and "Cable Select" (CS).
  3. tcgills
    tcgills
    Dec 26, 2002
    92
    is it a switch
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    This might help........
    [​IMG]
    Although the link positions may not be in the same place on your drive.
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    By the way, if you are new to PC hardware, be very careful removing the IDE cable from the original drive ! Pull on the plug, not the cable, or you could damage the cable.
  6. tcgills
    tcgills
    Dec 26, 2002
    92
    thanks nick very helpful :thumbsup:
