jumper cables
Discussion in 'Cables & Switches' started by Mr Cat, Aug 27, 2004.
  1. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,188
    Weardale
    +57
    I've just bought some terminated speaker cables - and I and thinking about buying some jumper cables…
    What are your thoughts on them..?
    Who does, them apart from Russ Andrews, and which ones should I buy, if any.?
    cheers
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    You could make your own out of cat5 network cable for a couple of quid. have a look for some of the many posts on here and elsewhere about this stuff, you won't be sorry.
    Owain
  3. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,188
    Weardale
    +57
    Hi, I decided to try and make my own Jumper...
    well, I was going to try and get a hold of some spades and the only places I could find (on a saturday afternoon!) was a hardware store and Maplins...well, they only sold these real cheap and nasty affairs (69p for about 16 pieces...) which I was going to attach to some excess centre cable I have Gale XL315).
    anyway, after getting home I was going to test the spades, but after finding them too small for the binding posts anyway I just fitted the cables (about 6' each) and the difference is great!
    the bass is great - nice and smooth...well worth the effort if you haven't tried them already...
