Juddering noise from speakers!
Discussion in 'AV Receivers & Amplifiers' started by Stellavision, Apr 7, 2003.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,343
    Southsea, UK
    +101
    I am having a nightmare with a juddering noise through my speakers. I've just changed my reciever to a Sony STR-DB1080 and never had this problem with my Sherwood. I've been told I may need a mains filter but I'm wondering why I did'nt have the problem with my old Amp/Reciever? Or could it be something totally different? Please help me, its driving me mad!
  2. nathan_silly
    nathan_silly
    Sounds like it's SNAFU.
    Have you read the manual/adjusted the settings?
  3. Stellavision
    Stellavision
    Apr 7, 2003
    2,343
    Southsea, UK
    +101
    What is SNAFU?
  4. nathan_silly
    nathan_silly
    "Situation Normal All ****ed Up"
    Sounds like your amp is faulty. If you've basically swopped the amp over- and I guess you know what you're doing, then most likely the decoding chip is not working.
