Juddering image whilst recording HD
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Genkisan, Dec 27, 2006.
  1. Genkisan
    Genkisan
    I found a problem last night with my SKY HD box that am curious if its me, my box or a common problem. Whilst recording Pirates of the Carribbean I tried to start watching it whilst it was still recording and and juddered like it was constantly losing signal. I left it last night expecting to have to delete it today and found it played great. So tonight I was sitting here watching the movie and half way through it my recorder starts recording Billy Elliot in HD and again the play back goes judder-city. So the common factor here is that I cant watch an HD recording whilst recording anything HD. In fact I tested playing back a standard SKY recording and found it fine...
    So...
    Just me?
    Or is this common?
    Appreciate any feedback.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    I've read a few posts from people who have had issues while recording two (high bitrate) HD channels and played back a third, first time recording one and playing back one has had problems.
    I wouldn't have thought the system would struggle with what amounts to 40mbps throughput but perhaps it does.
    Full system reset, try it again and if you have problems call SKY and raise hell:)
  3. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Does a planner rebuild defragment the hard drive?
  4. Russellgti
    Russellgti
    Nov 4, 2005
    523
    28
    +29
    Mine was doing this so I rebooted it by unplugging it for a couple of minutes. So far so good:thumbsup:
  5. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Not as far as I know, even considering the size of the files and the miniscule amount of fragmentation you could have compared to a standard PC enviroment I don't think a planner rebuild has the time to perform that sort of operation.
    Could easily be wrong though:)
  6. Mick4545
    Mick4545
    Dec 23, 2005
    275
    28
    Hereford
    +28
    I had this while watching Chelsea v Reading live, 2 frames per sec! Pirates of the Caribean the same live and recorded.
    I turned on my Humax sat reciever, had a look around the Continental channels, turned it off and went back to Sky HD. Lo and behold, everything back to normal.
    It was probably a coincidence but if it happens again thats the first thing I'll try. The second is the universal cure for most sat box ills, turn off and on at the mains.
    Mick
  7. Genkisan
    Genkisan
    Thanks guys... should have realised that in this day and age that a full reboot was the first option.. I will do that now and see how it goes later...
    I will let you know!
  8. CrispyToast
    CrispyToast
    Jan 21, 2006
    412
    Llantrisant
    +13
    I've had this also. Whole system was powered down while away for christmas and not long back so will have to see if problem has been cured. The live footy should do for this.
