JSRGB2VGA & Hitachi 42PD3000
Discussion in 'Plasma TVs' started by Cag, Jan 15, 2004.
  1. Cag
    Cag
    Nov 16, 2003
    230
    Newcastle
    +9
    Anyone use this with the Hit & has it made any improvements??
    Cag
  2. Dutch
    Dutch
    Dec 5, 2002
    2,584
    3
    North Yorkshire
    +271
    I'm not sure that the VGA converter is compatible with the Hitachi. You might want to check with John Sim himself. I think the component converter would work fine though. Hope this helps.
    Steve
  3. Cag
    Cag
    Nov 16, 2003
    230
    Newcastle
    +9
    Spoke to J Sim but he has not dealt with the Hitachi & not had feedback on it.
    Cag
  4. bossc@
    bossc@
    Dec 20, 2001
    1,100
    +236
    I seem to recall (from my dabbling with the 42PD3000 back in June/July time) that the VGA input on this panel is configured to be used with the supplied tuner box only - but I may be wrong:(
  5. manc
    manc
    Apr 3, 2003
    150
    19
    The converter does not work with my hitachi pma400e due to frequency input limitations in the screen. It is the same screen as the 42pd3000 although the media box may make a difference.
  6. Cag
    Cag
    Nov 16, 2003
    230
    Newcastle
    +9
    Thanks manc...just needed clarification. If need be will go for JS component
    Regards
    cag
