JS Technology VS Keene Electronics RGB to YUV Component Converter
Discussion in 'Projectors, Screens & Video Processors' started by bbasra, Jun 28, 2005.
  1. bbasra
    bbasra
    Sep 15, 2004
    1,600
    48
    Hounslow
    +34
    Anyone know the difference other than price between the
    JS technology RGB to Component (YUV) Video Converter
    and
    Keene APTUS2 COMPONENT TO RGB CONVERTOR
    Thanks in Advance.
  2. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    The JS one is simply built better using better (but yes, more expensive!) parts. Result is a cleaner, stronger image. Bit like the difference between decent cabling and using the cabling that comes supplied with the kit!! Not something worth skimping on with a setup like yours
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    If I was designing kit like this mine would look like JS internals :)
