J
JulianL
I'm pretty much set to buy a Panny 7 series panel so the only decision left is Scart board or JS-Tech SCART->VGA converter. I'm leaning towards the JST solution but the one thing that bothers me a bit is losing the automatic widescreen switching.
Could someone with this setup (or the 6 series is equally applicable of course) please talk me through how you deal with this in real life (I wil be mostly watching output from a Sky box and so expect to have quite a few 16:9 to 4:3 changes). Are you stuck with 4:3 broadcasts stretched horizontally or do some of the aspect settings on the panel still work via the VGA input? Are you able to manually adjust the aspect between 4:3 and 16:9 as required?
Thanks.
- Julian
Thanks.
- Julian
