JS Technology RGB/VGA Problems
Discussion in 'Plasma TVs Forum' started by Roohster, Nov 2, 2004.
  1. Roohster
    Roohster
    Jul 1, 2004
    3,661
    4
    Derbyshire
    +3,585
    Hi just bought a JS RGB to VGA converter to use with the RGB output of my SKY box and Panny plasma (TH42PW3)
    I've set everything up properly, used a high quality fully wired scart and VGA cable...and the picture sucks!
    The top third of the screen is "sheared" and the rest has jagged edges.
    Have I done something wrong? (SKY is definitely set to output RGB).
    Anyone had a similar experience?
    I bought the JS box after recommendations on here :(
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Have you contacted JS about it ?
  3. Roohster
    Roohster
    Jul 1, 2004
    3,661
    4
    Derbyshire
    +3,585
    Just emailed them, but (obviously) I wanted to use it tonight :(
  4. CARLOS
    CARLOS
    Feb 11, 2001
    6,412
    WEST MIDLANDS
    +1,404
    I can`t remember if the PW3 panel is the same as the PW6 but there are some settings in the menu for the VGA input, Make sure its set to input RGB signal and not component.
  5. Roohster
    Roohster
    Jul 1, 2004
    3,661
    4
    Derbyshire
    +3,585
    Well, after much fiddling and faffing, disconnecting everything, reconnecting, doing a reset on the SKY box...it works!
    Very pleased with both the results and the service from JS.
    My humble apologies to JS for besmirching their fine reputation!
  6. Roohster
    Roohster
    Jul 1, 2004
    3,661
    4
    Derbyshire
    +3,585
    Update on this...
    it turns out the original unit was faulty.
    I contacted JS and a replacement was sent out the same day.
    Excellent service!
