JS Tech Component Switch Box - Opinions?
Discussion in 'Cables & Switches' started by /\/\j17, Mar 12, 2005.
  1. /\/\j17
    /\/\j17
    Jun 28, 2003
    56
    London
    I've had a search but couldn't find anything so thought I'd ask - does anyone on here have any experience/opinions on the JT Tech. Component switch box?
    I've got a Panny 433MXE, with GameCube RGB->Sky RGB->JY Tech. GRBtoVGA converter-> plasma VGA and DVD player component to the plasma BNC jacks.
    To add to this I've just bought a PS2 and was thinking the best route would be to run that component in to a switch with the DVD player.
    I've been very happy with the RGBtoVGA converter, and their SCART switch box has had some good reviews but I've not seen anything on the component switch (is it just too new?).
    Or would you recommend a different component switch/different PS2 connection?
    Cheers,
    /\/\j17
