JS scart to RGB much better than Svideo?
M
MeToo
Have a panny PWD7. My sat box is currently hooked up via S-video. Picture is good but a little bit "smooth" for my likeing. The sat box has scart RGB. Is it worth buying the JS converter to go into the VGA? How much better is it going to be?
Mep
prepare to be amazed!...or at least very pleased :)....it will mqke a very noticable improvement in both sharpness and colour
M
MeToo
Thanks, just wanted to be re assured before I spend another 120 quid ;)
M
MeToo
As a side note the sat box (Dreambox 7000) can also output component via the same scart. I made a cable scart to 3 phono but it gave a very bad picture. Lots of background flickering - not nice. Dont know if its my bad cable or the dreambox's component output thats bad. Component should give a really good pic right?
Mep
It should do yes, I would guess it's something do with the sync but I'm sure somebody more knowledgable will be able to tell you more.
M
MeToo
This is how I wired the cable:
R - Pr : 15 core - 13 GND
G - Y : 11 core - 9 GND
B - Pb : 7 core - 5 GND
Dont know anything about the sync. Anyone?
Trending threads
