Js Rgb To Vga
Discussion in 'Plasma TVs Forum' started by swellmel, Apr 8, 2005.
  1. swellmel
    swellmel
    recieved my convertor today,usual setup is xbox connected to freeview box then scart from freeview box to plasma,so i connected scart lead to js box,then vga cable to plasma,i get a picture from freeview but nothing when i switch on the xbox screen says no signal,am i missing something or will the xbox not work with the convertor box.
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    it will but you must have an rgb cable for it...the standard one is not
  3. swellmel
    swellmel
    many thanks
    so from your reply is it then the cable from the xbox into the freeview box that needs changing also should pq from js convertor be better than the previous scart connection
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yep thats the one...ms do a hi def cable...have you got amp with optical input for sound?.....should give better pic beause the standard cable is just a composite job i think. Component is excellent if thats an option
  5. swellmel
    swellmel
    thanks i will change cable but should the js rgb to vga improve pq overall wether watching freeveiw or xbox or dvd
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i found it made a big difference over sky+ via scart
  7. swellmel
    swellmel
    just one last thing i noticed when i connected js box input had to be switched to pc on plasma to see picture is this correct
  8. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yes i think pc is the standard label for the vga input....you can change name of it.. i changed mine to stb
  9. fatherted
    fatherted
    Mar 6, 2005
    87
    Hampshire
    I wish STB could be changed to say SKY
  10. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yes so do i
