JS rgb to component on a 42px11 (PQ improvement)
Discussion in 'Plasma TVs' started by the highlander, May 16, 2005.
  1. the highlander
    the highlander
    Mar 29, 2005
    160
    Bonnie Banks O' Loch Lomond
    i have just set up a JS rgb to component on my LG42PX11 using Telewest cable TV. it has made a vast improvement on the PQ as the solerisation is vastly improved along with the clay face like affect( i had some problems especially with a dark skin tone, this seems to have been eliminated ) :thumbsup: the colours seem more vibrant and overall it has a crisper image .
    i have read that a few people are having problems with SKY/NTL on this plasma ( it should help with others also )
    well worry no more the JS rgb to component converter is a great little box that will work wonders with your PQ problems and i would recommend it :thumbsup:
    the more experienced AV people here would already know this :lesson: but i thought i would post this to inform the plasma virgins ( like myself ) that a relatively cheap(ish) solution is available to improve the PQ impressively on SKY/CABLE feeds .
  2. druss
    druss
    Hello Mr McLeod,
    Do you think you get better PQ by going straight from telewest to LG using your setup or by going component from DVD player to LG and a decent scart from Telewest to DVD?
    If doing it your way how do I get decent component from the DVD?
    Cheers, and 'there can be only one'... answer
  3. pjpar
    pjpar
    Apr 13, 2005
    37
    FIFE
    Highlander. the lead your using obviously made a difference.
    I am a total novice here what would I ask for and where would I get it. (or a link if you have one)
    Cheers.
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    www.jstechnology.com They are sponsors of the board. The better class of retailers keep them in stock if you are of a mind to walk through a door and buy one.
