JS Plasma > VGA Box - Problem !
Discussion in 'Plasma TVs Forum' started by MontyUK, Jan 30, 2003.
  1. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    All,
    Just got my new Panny this morning !! DVD player working fine, but I'm trying to connect my NTL Digital box via a JS VGA Box, and can't get it to work.
    I just get 'No Signal' on the screen, then every five seconds or so a flash of random colours, before it returns to 'No Signal' again ???!!! All connections seem secure, and the JS Box has a mains connection which seems fine (red light on box is on). Any ideas would be much appreciated.
    Thanks in advance,
  2. bobones
    bobones
    Jan 15, 2002
    453
    +7
    Just guessing, but are you using a fully wired or RGB wired scart cable?
  3. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    Obvious things but worth checking.
    Only the TV Scart is RGB out on the NTL boxes.
    Have you selected RGB output in the menu on the NTL box, default is PAL (composite).
    Kind Regards,
    James
  4. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    sorry for any trouble guys . . . but it WAS the SCART connection to the back of the NTL box, which felt secure but wasn't fully connected . . . all working fine now . . .Doh !
    Thanks anyway James and Bobones . . .
  5. d_devani
    d_devani
    This sounds very familiar..... I rang JS who helped me with this info
    firstly u need to set your ntl box to output a VGA input signal, followed by pressing the output or is it input button on the remote (i think top left hand side) this will flick through different inputs u want the VGA one
