JS Converter -> PW7
Discussion in 'Plasma TVs Forum' started by MCCURLEY, Apr 12, 2005.
  1. MCCURLEY
    MCCURLEY
    Sep 29, 2004
    33
    I know that perhaps this might be a more of cabling question but I know the majority of people with this setup will be in this forum. I am looking for some advice on the best way to connect my sky+ -> js converter -> pw7. Does the scart from to the converter have to be high end to conserve PQ
    Can anyone recommend a scart lead they have been happy with sub £50?
    Also what is the best VGA lead to take from the converter to the plasma?
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    any scart lead around £25 (ixos for example) should be fine unless you need a long run in which case the more expensive variety does justify the extra spend. Av Sales do a Van Damme red vga to vga for around £40.....whihc is possibly overkill but it's a good lead...JS Technology also sell cables on their site
