JPEGs or MP3s on HDD
Discussion in 'Blu-ray & DVD Players & Recorders' started by GadgetObsessed, Mar 18, 2005.
  1. GadgetObsessed
    GadgetObsessed
    Jul 6, 2001
    2,488
    116
    +1,202
    Many DVD players can display JPEGs and play MP3s. Most HDD/DVD combos allow you to copy a (non-copyrighted) DVD to the HDD.
    However, do any of the HDD/DVD recorders allow you to copy MP3 or JPEG files from a CD/DVD to the HDD?
    I'm particularly interested in the Panny E95 and I had some more specific MP3/JPEG related questions:
    Can it play MP3s/JPEGs direct from a DVD-R/-RAM or is it just CD-R/-RW?
    Can it play WMA files?
    Can it copy MP3/JPEG files from a compact flash card to the HDD using the PC slot?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    23,103
    Warwick
    +3,728
    The E95 (and E500) can only play MP3s from CD-R/RW. It can only read JPEGs on DVD-RAM, SD Card (or from any card/adaptor in the PC Card slot) or on the HDD.
    No. Only Pioneer and Toshiba models read WMA.
    It can copy JPEGs to/from the SD/PC card slots, DVD-RAM or the HDD. You can then view in a slideshow (as well as delete images etc).
    No. Virtually all DVD recorders will play MP3s but none will copy them across. I should imagine this feature will appear eventually - it seems an obvious use for the machines - but nothing on the horizon yet :( Have you thought about getting something like the NAD Netcap instead?
