JPEG onto DVD-R
Discussion in 'Blu-ray & DVD Players & Recorders' started by Daveandpauline, May 28, 2004.
  1. Daveandpauline
    Daveandpauline
    Can I put JPEG camera photos onto a DVD-R, it says in the Panasonic HS2 manual it will go onto a DVD RAM, but will it go on a DVD-R ??
    Dave
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    I don't believe so, you can use the ram because it acts like a hard drive, and hence the machine sees no difference in operation between the hdd and the ram.
    If you are trying to produce a slide show on a dvd-r to play in other machines it can only be done on a computer as far as I know.
  3. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,533
    38
    Nottinghamshire
    +22
    I imagine that your camera will allow playback of the pictures as a slideshow to view so you could always input this into your player and record it.
    I've done this, all be it with a philips to +R, but I think that I will still use nero visionexpress to produce and edit a slideshow just because of the flexibilty and quality but to produce them for compatability I'm sure it would help you!
    Hope this helps,
    Andrew
    PS As the above post I'm assuming you want to create a slideshow for viewing and not just jpeg on disc
