jpeg / mpeg to TV
Discussion in 'Photography Forums' started by matvib, Aug 14, 2002.
  1. matvib
    matvib
    Apr 28, 2002
    11
    4
    southampton
    does anyone know the best and cheapest way of getting pictures and movies from my pc onto a disc that can be viewed in compatible dvd's.
    I have tried nero, burned them onto a cd, and while the mpegs play perfectly, the jpegs only show 6 at a time, and i cannot show the full picture of each one.
    ive seen software called "picture to TV" which is going for about £40 but dont want to do this if there is a better option.
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,567
    +3,138
    Try winoncd 3.8 PE/5 or Ulead DVD Pictureshow.
