JPEG Loss of Quality
Discussion in 'Photography Forums' started by dazmcc, Jun 3, 2005.
  1. dazmcc
    dazmcc
    Although I am starting to shoot in RAW, I have hundreds of images that were saved as JPEGs straight from my camera. Many of these still need some post shot processing. Am I right in believing that if I open up the JPEG and edit it I will lose quality if I then save it as a JPEG again.
    What is the best way to avoid this? Should I convert the JPEGs to a format such as Photoshop PSD when I load them on my PC, then edit, then save as a JPEG once all editing is completed or is there a better way.
  2. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    All post processing is in someway destructive to the original data...it's one of the argument for using RAW then doing as much in PS in 16bit before finally converting to 8bit Jpeg.
    As to whether post processing a Jpeg and saving in Jpeg with minimal compression noticeably worse than saving as an 8bit Tiff i'm not sure, i doubt they'd noticeable in the final print. You could easily just try this yourself save in multiple formats and see if you can notice any difference, surely the most important thing.
  3. geeWcee
    geeWcee
    Oct 27, 2003
    1,420
    West Yorkshire
    +26
    Personally I convert to TIFF straight away. You can then edit to your hearts content without any loss then.
  4. Pink Fairy
    Pink Fairy
    Dec 5, 2004
    238
    Watford
    +32
    Open them as they are, edit if needed and then save as Tiff and they'll be fine :smashin:
  5. ASH1
    ASH1
    Mar 1, 2003
    1,221
    +63
    Me to, I convert from raw strait to tiff. There bigger files and so keep more of the information.
    ASH1
  6. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    My understanding is that edits/manipulations made on a 16bit file still result in data "loss"... you've just got more of a window than when performing the same manipulations on the equivalent 8bit file. Similarly TIFF is lossless but only when saving.
