Jpeg and Kodak Compatibility
Discussion in 'Blu-ray & DVD Players & Recorders' started by Garrett, Aug 13, 2003.
  1. Garrett
    Garrett
    Apr 21, 2001
    33,596
    2
    167
    The best thief you’ll never see.
    +4,470
    If a DVD states that it will play jpeg disc does this mean it will play Kodak disc?
  2. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Nope. Different formats: JPEG and Kodak PhotoCD that is.
    Arcams play both, don't know much about other players. I'm sure someone more informed will tell you if their favourite range of players can.
    StooMonster
  3. seamansam
    seamansam
    The latest Denon DVD2900 plays jpegs & kodak photo cds.
    Cheers,
    Seamansam:D
  4. mikeq
    mikeq
    StooMonster,
    I have the 88+ and had my holiday photos put on to CD by Jessops. They are just stored as jpegs under a directory on the CD.
    Should the player be able to read and browse to the relevant directory or should the jpegs be at root level (the player came up with a disk error when I put it in).
    Mike
  5. crash
    crash
    I think you might be referring to Picture CDd which is the successor to Photo CD. They are totally different systems in that Photo CD requires a player with the software built in and Picture CD has the software on the disc allowing it be run on most computers and some DVD players.
    Picture CD also uses a very low res image compared to Photo CD
  6. mikeq
    mikeq
    What I have is a CD with Fuji film picture viewer software (bit like slideshow software). The images are stored in 2 directories, one with lo-res images and one with hi-res images (1280x???).
    The images are just jpeg files, nothing proprietary about them. So from StooMonsters comment I was wondering how my Arcam can display them.
  7. dejongj
    dejongj
    Crash, thanks so much for that post. I thought I was going crazy as I found the resolutions so low on all the photo cd's that I had developed. Must have been the picture cd format, personally I do not think it is worth the 'cd' it is written on in such low resolution. Although I have it done through a Kodak lab.....
    PS The Limit 9900SE is playing it with no problem and contains a little directory browser....
  8. Garrett
    Garrett
    Apr 21, 2001
    33,596
    2
    167
    +4,470
    Thank for the replies I think I will go for a DVD player that states that it will run Kodak.
