Joytech AV & RGB
T
tm4
Could some please advise me - (this problem might seem obvious to some )I have a Joytech AV 1 which has Sky Digibox to first connection and then a Digisender (which has images from outside CCTV) on second connection.Sky output is RGB and the TV senses RGB and displays a good picture.The problem arises when I then select connection 2 on the Joytech - there is no picture.I know this must be because the TV is expecting RGB and the Digisender is not sending this - but how do I correct the situation without losing sacrificing the RGB image from the Digibox ?
