Joytech AV controllers
Discussion in 'Plasma TVs Forum' started by Supersonic72, Mar 8, 2005.
  1. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    This is a wee bit off topic for the plasma area, but its related closely...
    Has anyone knowledge of the -NEW= Joytech AV controller box?
    ...and particularly..what on earth is the RJ45 ethernet connector all about?
  2. hermanmunster
    hermanmunster
    Dec 23, 2004
    499
    Somewhere sunny and warm...I wish
    +24
    Can't seem to find proper spec on this one, but either they operate as a hub for PC connection, or if they are switched like all the other connections they could be used for VGA over ethernet. Great for long distance (>100m). Search these forums as these units (or their earlier cousins) have had mixed reviews.
  3. M-Jay
    M-Jay
    Feb 14, 2005
    15
    Hmmm don't know. Looks like 2 ethernet inputs and 1 output :confused:
    [​IMG]
  4. rich_jtg
    rich_jtg
    Mar 13, 2004
    241
    +13
    Has anyone bought one these boxes yet? I'm just wondering whether you can use more then one output simultaneously (i.e. Scart and composite)
    <edit> ignore me, I just realised the release date has been put back again!
  5. neil c
    neil c
    Mar 25, 2005
    537
    +3
    Ive been considering the old version, which doesnt have the ethernet connections. Ive only got a single RGB input, and this would save alot of hassle for all the RGB and optical devices I own.
    Last I heard the AV centre will only output what has been input, i.e. if you connect an xbox via RGB and optical, then the audio will only be output from the optical output and not the stereo output. Although this new version may be different.
    I havnt used one, and Im concerned that the RGB picture quality may be affected, so Id be interested to hear from any owners on the performance.
