Joytech AV Control Centre
Discussion in 'LCD & LED LCD TVs' started by tmp, Jan 8, 2005.
  1. tmp
    tmp
    Nov 23, 2004
    268
    Bristol
    +12
    May be of use to you
    EDIRECTORY
    £26.99 Incl VAT (EU) Saving £22.99 - Offer ends 14/01/2005
    JOYTECH’s versatile JS965 AV Control Center allows you to connect multiple pieces of Home Entertainment equipment to one TV. Up to 4 pieces of AV equipment can be connected without having to disconnect and re-connect every time. The AV Control Center offers 4 fully wired RGB SCART inputs, 4 Digital Optical inputs, 4 S-Video inputs, 4 Composite Video and Stereo Audio inputs and one matched output. JOYTECH’s Signal Regulator Technology™ assures that picture and sound quality from all AV sources remain pin sharp and ultra stable, whilst the simple input channel selector allows you to page through and select the AV source you require.
    Features
    x
    Input Impedance
    Audio: 1k Ohm
    Video: 75 Ohm
    Output Impedance
    Audio: 1k Ohm, 0db
    Video: 75 Ohm, 0db
    External size 430x55x255mm
    Weight 1.97kg
    Accessories included
    A/C adapter
    SCART to SCART cable
    S-Video to S-Video cable
    Phono to Phono cable
    4 S-Video inputs
    Master Out of RGB SCART, S-Video, Optical and Phono (RCA)
    Remote controller unit with operational distance of 10 Metres.
    Solid metal casing for enhanced electrical interference screening
    Stylish design to blend in with your existing AV equipment
  2. SLIM
    SLIM
    Jan 1, 2004
    1,352
    38
    +17
    look's good
