Joytech AV control Centre or Quintro?
Discussion in 'Cables & Switches' started by Juliesinar, Jan 7, 2005.
  1. Juliesinar
    Juliesinar
    Oct 28, 2003
    872
    +51
    I'm trying to sort out my AV cable jumble and want to buy some sort of device so I can plug my scarts in which will switch my devices as I'm haveing trouble trying to connect them up to my TV which only has 2 scarts, only one being RGB.
    I have Sky digital, Tivo, Dvd player, DVD recorder and a Gamecube. There seems to be quite a difference in price from the Joytech and the Quintro (£27 vs £80), am I right in assuming the quintro is more versatile regarding recording options? For example I could record to DVD from either Tivo or Sky using the quintro but not the joytech? Probably I'm a bit confused, any thoughts appreciated.
    Also, the cheapest I have found the Quinto is £79.99, is that a good price?
    Thanks in advance,
    Julie
    :confused:
  2. CatManDo
    CatManDo
    Nov 5, 2003
    1,754
    South Yorks
    +242
    I have the joytech and it works fine....I can recommend.
    The only drawback I can tell is that with the Joytech you have to manually switch using a remote, whereas with the Quintro I believe it is automatic.
    HTH
  3. elliott-cardiff
    elliott-cardiff
    Aug 22, 2004
    53
  4. thfccambs
    thfccambs
    Jul 17, 2002
    19,095
    White Hart Lane
    +5,168
  5. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    does that quintro have a scart built in so you dont need to buy a seperate scart to connect the swuitch box to the tv, also is it worth the money, like is there any picture/signal quality loss??
