Joytech Advanced SCART-RGB through Sky Box?
Discussion in 'General Video Gaming Chat' started by Shady Deal, Apr 21, 2002.
  1. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    Have just bought one of these and I must say it seems very good value for
    money compared to MS Official one.
    I have one question though, I loop it through my Sky Box as I only have one
    RGB input on my TV.(TV = Tosh 46 RPTV)
    Sky Box on AV1 using RGB happily.
    Is the Joytech Advanced Scart only wired for RGB or does it do composite
    aswell??
    i.e Is there a chance that through my Sky box I might only be getting a
    composite signal?
    The picture looks ok, but is there a way to tell that is is infact RGB?
    Regards
  2. Army Bloke2
    Army Bloke2
    The RGB signal will be a lot darker than the composite one. I used to run my DVD player through my Sky + scart and that was outputting RGB so I see no reason why the xbox wouldn't do the same.
