Joining Xbox live tonight. Please help.
Discussion in 'Xbox Forums' started by Bristol Pete, Mar 17, 2005.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    Have a two month trial pack which I am going to set up tonight :thumbsup:
    Can I use my usual ethernet cable to connect xbox to modem or do I have to buy something from Game etc :confused:
    Thanks in advance......
    Cap :)
  2. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,411
    41
    Berkshire
    +17
    normal cable is fine and all you need, (headphones are worth buying though)
  3. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    Thanks Cyrus. Will get head set etc in future if I think its good enough.
    Am sooooo exited :clap:
    Why the hell do we have to work!!! :mad:
    Cap.
  4. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,963
    2
    2
    Manchester
    +4,474
    Let us know what your Gamertag is when you get sorted, usually someone around from here who'll give you a game. :thumbsup:
  5. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    I hope to be Captain Benefit.
    Can I choose it or does the machine generate it???
    Cap :)
  6. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,963
    2
    2
    Manchester
    +4,474
    You choose it yourself, but you'll find alot of the best ones will have gone now. Its good to have a Plan B in mind just in case. If you run out of ideas, it does generate some suggestions for you.
