Joining two telephone cables
Discussion in 'General Chat' started by Sheepdisease, Jul 11, 2015.
  1. Sheepdisease
    Sheepdisease
    Jan 26, 2009
    314
    +5
    Hello there,
    I have an alarm system fitted to the house, which connects to our phone line. I want to divert the route of the phone line so I cut the plastic jack ends off the alarm line and a telephone extension cable so I could feed it through a hole I drilled in a cross member in a partition wall.
    At this point I noticed that 1. the copper cores are strands rather than solid 2. the cores are thin so twisting them together to join is out of the question and 3. the alarm line has four cores and the telephone extension has two.
    Can someone please tell me how I get around the first two hurdles and whether the third point is going to be an issue?[​IMG]
  2. hyperfish
    hyperfish
    Nov 15, 2009
    10,380
    +10,511
    Solder and heat shrink to do the job properly.
  3. phillyd1981
    phillyd1981
    Dec 10, 2006
    2,577
    +1,489
    Telephone jelly connectors will do the job fine seen them used on a few jobs.
    2 WIRE TELEPHONE JELLY CRIMPS 8A TELECOM CONNECTOR x 100 | eBay
    Can't really help with the wiring but was the alarm working fine of the extension lead before you mullered it? if so connecting the two same colours back together should work or failing that a good old search of google will be your best bet.
  4. MartinMiller
    MartinMiller
    Oct 12, 2007
    2,091
    116
    Hamilton, South Lanarkshire
    +664
    Re wire to do the job properly........
  5. Sheepdisease
    Sheepdisease
    Jan 26, 2009
    314
    +5
    Google is how I arrived at these forums, I hadn't tried the extension lead with the original cable for the alarm prior to cutting so I don't know whether it requires all four cores.
  6. its_all_Greek
    its_all_Greek
    May 8, 2009
    4,792
    Nottingham
    +2,609
    Haven't dealt with alarms in years, but i suspect that 2 cores will be for an alarm signal and 2 cores for an anti-tamper circuit, the wiring instructions for the alarm panel should confirm this.
  7. Chadford
    Chadford
    Mar 5, 2006
    6,016
    LS6
    +2,600
    If you don't own a soldering iron. Quick and dirty, twist the wires together and put a big gob of Araldite over the connections.
    :rolleyes:
  8. EarthRod
    EarthRod
    Jul 15, 2008
    17,958
    England
    +8,077
    ^^^ Please don't take that seriously!!
  9. Chadford
    Chadford
    Mar 5, 2006
    6,016
    LS6
    +2,600
    Actually, yes you can.
  10. Sheepdisease
    Sheepdisease
    Jan 26, 2009
    314
    +5
    After receiving your replies I have decided to get a much longer 4 core alarm system cable, the correct terminals and I already have a crimping tool. Thank you for your help.
