joining the three matrix films together
A
AVMADMAN
I am using dvd backup to record these films onto my HCPC.
Does anybody know how i can join the three together to make one long film???
other plans are for Star Wars and LOTR If i can stay in my seat long enough to watch them...
SLIM
ok all you nead to do it rip the dvd's to ure HD
Then convert them in to AVI
Then join the films useing a avi joiner
Then shrink the 1 avi film down useing KVCD
Thats it ure have 3 films all joined and only say around 900 megs maybe a bit more bit less give are take
Hope that helps
A
AVMADMAN
could i still use theatertek for playback SLIM?
drummerjohn - have you joined films together before on dvdshrink?
And thanks Krammer good site...
B
BOD
no I havent but it is very easy to do apparently. I will have a go tonight with my 3 matrix films and let you know.
SLIM
MMi dont no what the prog is but i dont see why not if you nead help just let me know and ill help you all the way from ripping the films to ure HD to being able to put ALL 3 films on to a 800meg cdr are there about but you get what im saying
Are if you wont the 3 films on 1 dvd-/+ cd thats easy to :thumbsup:
B
BOD
OK - joined all 3 matrix films together usind DVDShrink - its a doddle. But there is a downside. Its sheer luck that the join would look proffesional.
Example:
End sequence (where Neo flies upto the sky) of Matrix 1 launches into Rage Against the Machines Wake Up music. Cut from that to the very quiet start of Matrix 2 and.... Oh dear.
So joining films together is really easy - making it look good is another matter.
SLIM
you dont wont to use any progs to shrink the dvds down
you wont to rip just the films to ure HD then convert them to avi then join the avi files together then you nead to rip the sound from the 1 big file you have just made you nead to keep the wav file somewear on ure pc then you nead to take the 1 big film and make a copy of it as a KVCD then you nead to but the kvcd and the wav file back as 1 thats it
A
AVMADMAN
I am sure i can come up with something even if it involves cutting a bit off :nono:
And if you dont mind SLIM i would very much like to come back to you once i have tried BODS way as i like the idea of ripping films down to small sizes a telephone conversation might help???
if you want to PM me your telephone number SLIM I could ring as i might have too many questions...:confused:
SLIM
AVMADMAN
you have a pm m8 with a contact number ok
SLIM
((( :lesson: All so i would just like to point out that any info i give out can be found on the internet freely and is for information purposes only and should not be attempted :lesson: )))
65-inch LG C1 Review coming soon to AVForums
