Joining speaker cable?
Discussion in 'Home Cinema Speakers' started by Ross007, Jun 7, 2003.
  1. Ross007
    Ross007
    Feb 11, 2003
    668
    28
    Bristol
    +40
    The cable I want to join is for the rear surrounds, it is less then 100 cm short.
    Can I just add some extra cable or should I look at getting new cable?
    If I can just add some cable what is the best way of joining, would twisting and insulating the join be ok?
    Any advice much appreciated.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,321
    Somewhere in South Yorkshire
    +5,679
    Solder is the best method. It's reliable, fairly easy, has near-perfect electrical properties, and won't pull apart easily. Oh, and some insulation, too.
  3. bob1
    bob1
    Nov 7, 2002
    4,354
    Sheffield
    +131
    I did this but used solder,there is a method for joining cables without solder but i would not recomend it for speaker cable.
