Joining avi files
Discussion in 'Desktop & Laptop Computers Forum' started by onefivenine, Jun 7, 2005.
  1. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
    hi,
    Is it possible to join avi files in the same way as binaries using a DOS copy command?
    eg
    copy /b <file1> <file2> <outputfile>
    or do you need a tool?
  2. Da_Rude_Baboon
    Da_Rude_Baboon
    Jan 12, 2005
    492
    28
    +55
    I dont think so. It might join the files but i doubt they would play as the time coding etc would be wrong.
    I used a program called DVD Lab Pro (iirc) to join avi files before. You can also then convert them .vob and burn them to DVD.
  3. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
    Cheers for the tip baboon!
  4. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    there is a dos command but i cant remeber it offhand. its simple but anything to do with avi manipulation you must use VirtualDub in my opinion.
  5. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    There is a freeware program called 'Diko' which I have used in the past to join two divx files together, very simple to use and good results.
    I think it does all avi files, but not sure :smashin:
    (for ac3/5.1 audio you need to buy/obtain a plugin)
  6. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    VirtualDub is good. Just set audio and video to direct stream copy then append and edit all you want :)
  7. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    Another free program that can join video files as well as repair damaged files, extract the audio track from video files and convert to and from various formats is ASF Tools:
    http://www.geocities.com/myasftools
