New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
Depends on the make and model, cisco wireless access points for instance
can operate in bridged mode to do this. Each vendors implementation of this
is often propitiatory though, so they'd most likely need to be of the same type.
How far away from each other are you? Might be easiest to run an ethernet
cable between the two routers (again if they'll support having one port configured
slightly differently)
