Join in s-video cable - bad idea???
Discussion in 'Projectors, Screens & Video Processors' started by Mr Cheese, May 18, 2003.
  1. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    412
    Down South
    +19
    I run an s-video cable to from my DVD player to my amp and then another 5m s-video cable to my pj. I have relocated the amp, and now the amp to pj cable is 3m too short.
    I could put a 10m cable in, but the cabling is pretty inaccessible without taking up the floorboards (again!). The easier option would be to put a coupler in with an additional 3m cable. Would this degrade the pj's pic quality - ie having a join in the cable?
    Has anyone done this?
    TIA
  2. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    The join, probably not. The difference in cables, perhaps.
    What you have is a transmission line, with a certain characteristic impedance (75 ohms). Signals travelling down the cable expect this to stay at 75 ohms and any discontinuity could cause them to be reflected back to the source. End result, poor picture.
    With a 10m length, you want to be using good quality 75 ohm cables, in the one run. Other than this, no reason not to have a 10m run.
    All the best,
    Dr John Sim.
  3. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    412
    Down South
    +19
    Ah well - thanks for that - looks like it's time to rip the floorboard up again !! At least they're screwed down now so should be a lot easier second time around.
    BTW my skybox goes through one of your RGB to S-video converters (Mk 2), Bl**dy fantastic!!:smashin:
    All the best
    Mr Cheese
