John Lewis refund?
Discussion in 'Plasma TVs Forum' started by madcyril, Aug 26, 2005.
  1. madcyril
    madcyril
    May 30, 2004
    1,049
    Manchester
    +94
    What is JL like for getting a refund.I bought a Sony XS1 from them 8 months ago and it has an intermittent fault.The screen occasionally goes blank for a second when watching thru component.Sony are aware of the problem as it appears to be fairly common and say there should be a fix soon(no date).There is a post elsewhere stating the same problem.He had engineers playing with his TV but it wasn't sorted so I am not confident.
    I would rather not have engineers swapping bits on my TV 'to see what happens'.I prefer a full refund and spend my hard earned on another TV.
    What are my options.Has anyone had a refund from JL,where do I stand.
    Thanks for any help people.
  2. StrongSilent
    StrongSilent
    Jun 27, 2005
    498
    +6
    You may be better off starting with Sony themselves. Once you've made a case and an engineer hhas verified you have the problem, they should authorise the refund, JL will then have no case for refusing.
    Recently had to to this myself but with Panasonic. It sometimes comes down to who you get through to on their Customer services number.
    Good luck.
  3. Blue.Rocket
    Blue.Rocket
    Aug 20, 2005
    711
    Breckland Norfolk
    +26
    Hi;
    Can't answer your question, but just noticed that when viewing the audio and TVs etc, almost everthing has a 5yr guarantee, and the price's are not that bad........
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    Did you make them aware of the fault within 6 months?
    If yes, you have a good chance, if no then they only have to repair or replace.
  5. madcyril
    madcyril
    May 30, 2004
    1,049
    Manchester
    +94
    JL are as yet not aware of the problem,I've been dealing with Sony.A swap is out of the question as it is a fault that is apparent on all XS1 TV's so I believe.
    I've noticed JL no longer have the 42" on the website.
  6. nheather
    nheather
    Oct 6, 2004
    17,248
    167
    Horsham, West Sussex
    +6,547
    Why don't you expalin the situation to JL, perhaps putting it in writing so there can be no confusion and see what they say.
    I imagine that JL warranties are like most - that is
    (i) Attempt a repair
    (ii) If a repair isn't possible or beyond econmical value then replace with an identical model
    (iii) If that model is no longer available then offer an alternative upto the original purchase price
    Since you say that the fault is evident on all TVs of that model then you will eventually end up at (iii).
    What you need to do is to convince JL that they are going to end up at (iii) anyway so they may aswell do it straight away to avoid wasted time and money.
    I doubt they will give a cash refund. If you really want this you would have to argue that none of the alternatives in (iii) are acceptable but that may be a hard slog.
    Cheers,
    Nigel
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    As you have never told them about the problem they only have to do as Nigel said above and offer i, ii or iii.
    If you had told them straight away you would have been entitled to a refund.
    But there are loads of new screens about to arrive so plenty of options.
  8. madcyril
    madcyril
    May 30, 2004
    1,049
    Manchester
    +94
    Thanks for the replys guys,I'm going away on my bike tonight for a week so I'll put it on my wife's 'jobs to do list' and see what they say.I'll post any outcome.
    Nurburgring here I come :D
  9. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    You lucky bastard!! :smashin:
    Post some pics when you get back, I want to see one with the camera an inch from the ground coming out of the third corner at 140mph! :) Enjoy!
  10. madcyril
    madcyril
    May 30, 2004
    1,049
    Manchester
    +94
    I'll see what we can do,was hoping to video a couple of laps but I couldn't get a decent tank mount in time so you will have to take my word that I will be doing 175mph on the straights-oh yes.
    By the the way If I don't post by next weekend the Cyril has not made it back but he would have been smiling big time :D .
