JFK R4 DVD problems
Discussion in 'Movie Forum' started by Desticado, Jun 20, 2002.
  1. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    I recently got the R4 JFK disk that was just released.
    From scene 48 onwards there is pixalation / blocking problem with the picture and sound. The disk looks to be fine and i've tried cleaning but to no avail.
    Anyone else had this problem at all?
    Regards
  2. malcy
    malcy
    Saw this discussed when disk came out. It was an authoring fault which screwed up the 2nd layer so you can't watch end of film. Need to return as faulty.
    Not sure if they have repressed the disk yet to correct the fault. May be worthwhile trying an Aus DVD site / forum
  3. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    +6
    anyone else heard of this?
