jewel case template
Discussion in 'Hi-Fi Stereo Systems & Separates' started by mivec, Oct 11, 2004.
  1. mivec
    mivec
    Mar 29, 2004
    60
    Where can I download a basic jewel case template, I have tried one form AMF? but cannot locate the files on my PC.
    Any help appreciated.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    I have created my own.
    I just measured the size of the covers from one of my CD's and then created an outline in MS Publisher. When I create a new cover I just scan an image or add text etc and then fit it into the box created in the template. This has always worked well for me and is better than the template in Nero etc as the front cover is alway single sided, but mine are double width and I fold them in half to create an inside design for the jewel case.
    Mark.
  3. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,441
    I simply use word, insert whatever two pictures you want and resize front cover to 11.98cm high by 12.07cm wide, back cover 11.75cm high by 15cm wide.
