jesus im lost !
Discussion in 'Projectors, Screens & Video Processors' started by the klang, Dec 24, 2004.
  1. the klang
    the klang
    Dec 21, 2004
    449
    ilford essex
    +3
    help im lost,
    i have a pioneer 502 mxe,(50")plasma ,no hdmi or dvi just 15 pin mini d sub and a few other standard video conections.i read somewhere that you can use a converter that will go from a dvi-i to mini d sub (analog) but not dvi-d which is digital only,if this is the case then how can i find out the type of dvi output these new hi def dvd players have because thay dont seam to ever say.im after a 720p signal from a dvd player .
    any help would be great...
  2. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    I'm a little bit further down the road than you are. I was going to get DVI or HDMI for my new Panny TH42PHD7 but Panny thwarted that plan for the moment.
    Most DVD players seem to have the DVI-D variant. You're right you can't go directly from DVI-D to vga. This little chart shows the possible connections. So I guess either you get a DVI card, invest in a scaler or a DVI-D to vga converter. My scaler (iScan HD) can take DVI-D or I input or output.
    My DVI plan has been abandoned because the Panny DVI card can't accept 720p/50. I couldn't handle the thought of 720p/60 and even the slightest judder. So I'm waiting to hear if the new HDMI card will handle it (not holding my breath though).
    It may be that the Pio DVI card can't handle 720p/50 either btw. Worth checking if you go down that route unless frame rate conversion doesn't bother you.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    You wont get a DVI-I output on a DVD player. You need to go in to the HD15 input on your display. I'd look at getting a scaler to do this if you want to increase quality just now. When we start getting HDMI/DVI-D with HDCP encrypted sources you are very probably going to have to get a new display if you want to see them in all their glory
    Gordon
  4. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Except a Momitsu V880!
    Steve
