toddmarshall
how do i force the ps3 to do 24 frames, cos I have put it on by going to the bd/dvd settings but when i clik info on the tv ( samsung le40m87) it still says 60hz?
Personally I don't see the point of 24fps anyway, the film is longer for a start. Can anyone explain what the advantage is apart from it being "how it is in the cinema".
For xmas santa brought me the departed, planet earth and goodfellas on blu-ray.
I have noticed whilst watching these that the playback in quite jerky, for instance if the camera is panning over some mountains on PE, there is like a judder on the screen. Its not a massive problem but just wondered if my settings are wrong.
I have got a tosh 32WLT68, what should my ideal settings be?
Many thanks
Gutted!!! Although i was thinking about going bigger and getting a fullHD TV so you might of just made my mind up now.
Thanks for the reply
It will make no difference.I think you can turn off the 24fps in the BD/DVD settings menu on the PS3, gives you the option of on off or auto, try with it off and see if it helps on the scenes causing you grief
just realised that my current TV is 32WLT66 not 38
I'm such a dope, does this make any difference about the 24fps issue?
Not sure if im in the right thread or not, but here goes anyway.
Awaiting arrival of Sony 40W3000 panel but would like to know what the optimum settings are for using the PS3 as a BD player. By this I mean what internal PS3 settings are people using along with their panel settings?
Any help or links to appropriate threads/sites would be greatly appreciated.
