Hey Drew,
Sorry, I thought I posted my initial impression on here, but had sent it to a friend instead.
I haven't EQ'd or got carpet down, its still just floorboards. I can't really make any true judgements with the state of my room and due to my ill-health I simply cannot do as much as I would like at all. I ran quick tests without my subs, running LR and LCR full range.
I think the JBL SAM 1HF/ 2LF are phenomenal sounding speakers. I couldn't listen loud at all yesterday, especially with no carpet. However, I listened to two go to favourite songs first, Beat It by Michael Jackson and Reckoner by Radiohead -
- two master track and album productions. My immediate impressions were how impressed I was by the SAMs balance/ flatness, clarity, poise/ control and tightness. I also quickly realised how loud they can go. There appear to sound more effortless than my old 3677. They sound cleaner and perhaps more clinical in tone than the 3677, which I was missing the warmth of a bit. But again, I can't compare anything accurately mainly due to the room condition and that may be due to that.
I then tested a few of my go to scenes from Man of Steel, Blade Runner, Blade Runner 2049 and Jurassic Park. All sounded great. Sound filled the room easily. One of the things I had expected from the SAMs was a balance of best of the M6 and 3677. And that is exactly what I felt: there was definitely the presence of detail across the frequency range, which I found lacking very much with the 3677, in comparison to my M6. High end detail was superb and the mid-range hit more like my M6. I was very impressed with the lower mid-range and low end capability of the SAMs. I heard a lot of sounds and detail that I've never heard before with either my 3677 or M6.
I'm impressed by how good the centre channel sounds so low. But that stand and 6.5 degree tilt is certainly helping a lot. It's not ideal but works very well, considering that there is no carpet and there was no EQ. The biggest negative are L and R being either side of the screen. As I had gotten used to how much better my 3677 sounded beneath the screen, closer matching an AT experience. So, I'm going to get some more ISO-155 stands and try LCR beneath my screen next. But it's certainly doable for now. I know this is not the best the SAMs can sound by far due to their compromised placement and current room conditions, so it's even more impressive when considering that.
I might do some more listening today, but it means carrying my very heavy PC up and down between rooms.
It's really nice having such nice speakers back in the room as it's been a short while since I have had any in action with an AVR, apart from my trusty little digital mirco monitors, the Edirol MA-10D.
Rajiv
Impressions - Part 2: thoughts on SAMs beneath screen VS elevated beside screen VS M6
Last night I got to a more in-depth comparison between the SAM L/ R on stands either side of screen, LCR beneath screen and M6 L/ R beside screen. Again, no EQ. I found that whilst there was more cohesion gained with the LCR beneath the screen and maybe slightly L/ R sounding less distracting/ obvious, the sound suffered too much as as result from being so low to the floor. The centre channel SAM still sounded impressively clear and crisp though on the ISO-155. Note that I didn't use baffle blocks to elevate 1HF for L & R (there a bit shorter than 2LF). The centre 1HF was elevated. I used more high density foam blocks for L & R and rubber door wedges to tilt them up. I know the ISO-155 would have helped them considerably, but the other issue was that the sound just sounded off from coming from so low. The 3677 worked so well on the floor and beneath the image due to their height and my low seating height at the time. I've accepted that I simply can't use the SAMs that way in a non-AT setup as I had originally hoped, the sacrifice to the quality of sound is too great for me.
With L/ R elevated beside screen, the soundstage came alive and the true qualities of the SAMs shone through. With the centre still beneath the screen and low, as a whole, the front soundstage was just fine. Separation was better though needing a bit more cohesion perhaps. With LCR below the screen, the combined width of both HF & LF modules mean that they are close to each other. It took a while getting used to having the majority of sound come from either side of the screen again, but after about 1 hour, I was quite used to it again. Stereo music was bliss and I was more immersed in films.
I decided to hook up my M6 L and R, with centre SAM still on for films, to see just how much my impressions were correct about the SAMs combining the best of what I love about the M6 and 3677. Do the SAMs really have the high end detail of the M6 that was missing from the 3677? I was positively surprised to hear that I was spot on: The SAMs really shone through, producing maybe even more detail than the M6. Surprisingly though, the M6 still sounded like they had the SAMs beaten, as it did the 3677, in the low mid-range detail. For example, the rolling thunder in the back ground during the scene in Blade Runner (1982) before Rachel sits down to play the piano was more defined and detailed form the M6. Like the 3677, the SAMs sounded softer here. Another area where I was again impressed by the M6, was its mid-range bite and tightness. My go to track for this is Trivium's Shogun which features a classic mid-range heavy components typical of metal music. The guitars cut through tightly just as I remember the M6 to always re-produce them. Whilst on the SAMs, like the 3677, they sounded softer and looser, not bad by any means, however. And this is where I tend to come back to saying that for critical monitoring and music listening, the M6 had the 3677 beat easily. Another example of the tight mid range of the M6 is the docking scene in Interstellar and opening sequence in Blade Runner 2049, I was always more immersed and 'locked-in' to the sound and overall experience in these scenes due to this. I wasn't able to test these scenes with the SAMs on this occasion, however. Listening to my M6 again after all this time, I was also reminded of how thin and small a sound they put out compared to a speaker like the SAM 1HF/ 2LF. One thing I was constantly thinking was if the SAMs were worth it for my needs and room, and it was moments like these in which the improvement and performance of the SAMs reassured me that it was, at least for the most part.
Switching over to Van Morrison's Caravan off of Moondance, I was very impressed by how much of the M6s qualities the SAM had that I had longed for along with the 3677s warmth and much fuller sound. Caravan was the song that really awakened me to the potential of the M6 as stereo music speakers in my final a/ b tests with my old 3677. But now, the M6 were finally beat by the SAMs. The SAMs re-produced a warmth and fullness to the guitars and saxophone as well as the clarity and realism of the playing and sound itself that was a pure pleasure to hear. Instrument separation was superb between L & R and considerably better than my 3677, from what I can remember.
The same warmth, clarity and fullness of sound shone through during the end credit sequence in Jurassic Park (1993), a sequence that I love to immerse and lull myself in, alongside the sleepy, warm soft orange-yellow hue of the image. The sparkle of the high end and conviction of rolling drums and crescendos were fabulous. However, I didn't get the same room filling sound as I did from the 3677. I did expect this to be the likely case with the SAMs, though. My go to sequence for this test is the scene in which John Hammond steps out of the helicopter as him and his company first arrive in the Park. The swelling of the classic theme really filled my room from the 3677
Going back to the issue of sound not being married to the on-screen action in a non-AT setup, the opening scene of Jurassic Park I find is always a good test. There are bustling plant leaves which sway between left and right speakers, and the raptor in its cage which comes into shot from the right speaker. I concluded that in the case of the SAMs, these sound placement itself was maybe as much an issue with LCR beneath the screen as it was with L & R beside the screen, again, for the reasons mentioned earlier. That said, the immersion from the superior quality of sound overall with L & R beside screen helped draw me into the experience that much more to the point where my brain was able to put two and 2 - sound and image - together well enough.
Finally, I can't imagine a smaller centre/ centre/ speaker that can work horizontally being much better if at all, than the SAMs, regardless of their size and how low I have it. That said, I am keeping myself open to anything like the SAMs that might be smaller and thus work better in my room. But having said that, if I do go with an AT setup in the future, the SAMs would be perfect.
In conclusion, at least for now, for those that were interested in buying the SAMs/ centre from me, I'm quite confident that I will be keeping the them for now based on my tests. However, there was a JBL/ Synthesis range that I remember seeing recently that had a centre that could be placed horizontally, and I was thinking that it might work better for me. But the SAMs current placement and superb performance, though compromised, sounds excellent to me and will only sound even better once the room is furnished and with acoustic treatment. If I do have a change of mind and heart however, you'll all know for sure!
Wishing everyone a very Merry Christmas,
Rajiv
