Hi folks...
I currently have a JBL E150P sub hooked up to an Onkyo 805.
Now from reading both manuals my understanding is that, with cable connected from the amps "Sub out" connection to the sub's "LFE line level in" connection, the sub should be set to LFE mode instead of normal.
Is this correct?.
If thats the case, the sub's crossover dial is then not used?.
So if i have the amps crossover set to 80hz for my speakers (70 for the fronts), is this a good set up?
Would there be a better way to set up or is this covering all bases??
Stu
Is this correct?.
Stu
