JBL Speakers -> TV connectivity advice!
Discussion in 'Cables & Switches' started by abrown666, Apr 21, 2007.
  1. abrown666
    abrown666
    Hi there, I'm a real AV newbie so apologies if this is a very simple question!
    I've just been given the JBL Creature II speaker system. This comes with a mini-stereo jack connection so looks like I could plug straight into my iPod etc.
    What I want to know is can I connect this to my tv? My tv appears to have RCA connectors (says R1, L1) on the back for audio connections.
    Is there some kind of converter that I can buy that will do this for me?
    Many Thanks
  2. Graham_E
    Graham_E
    Nov 8, 2004
    167
    +10
    mr brown, dead easy, this one.
    You need a "3.5mm to 2 phono lead".. everyone sells em, so you'll pick one up easy for under a tenner.
