JBL ESC XCITE 5.1 Problems
Discussion in 'Home Cinema Speakers' started by tac123, Aug 4, 2013.
  1. tac123
    tac123
    Aug 4, 2013
    Hello, I have recently bought a second hand JBL ESC XCITE 5.1 Surround Sound sub and speakers, the unit was working great in the downstairs living room, I went to move it upstairs to my bedroom and plugged it in. The on Light comes on, but none of the buttons are working and no other lights will come on. I have checked the external fuse on the rear of the sub, which is working. Any ideas on what could be wrong, or is it a case of taking it to a repair guy?
    Also the unit is very similar (almost identical) to the JBL ESC333 for a reference.
    Thanks in advance
  2. Rodders53
    Rodders53
    Dec 8, 2007
    5,213
    Bedford
    +944
    Have you tried to remove mains power and leave it off for a fair time ... say 30-60 mins ?
    Sometimes you need to let power supplies' energy stores die away completely before re-powering in lockup situations.
