jbl e100 worth it
Discussion in 'Home Cinema Speakers' started by showcase, May 31, 2005.
  1. showcase
    showcase
    hi
    are the jbl e100 enough for the marantz 8500 or yamaha 2500, can the av/amps run the jbl's effecently, in lower vol and as well as high vol
    has any1 got any experience of jbl's
    appreciated in advance
    see the pic and spec
    NORTHRIDGE E SERIES - E 100
    3-Way dual 10" floorstanding
    SPECIFICATIONS:
    General Section
    Maximum Recommended Amplifier Power: 250W
    Power Handling (Continuous/Peak): 125W/500W
    Nominal Impedance: 8 Ohms
    Sensitivity (2.83V/1m): 91dB
    Frequency Response (-3dB): 33Hz ¿ 20kHz
    Crossover Frequency(ies): 1000Hz, 5000Hz
    High-Frequency Transducer: 19mm Titaniumlaminate dome, shielded
    Midrange Transducer: 100mm PolyPlas,#8482; shielded
    Low-Frequency Transducer: Dual 250mm PolyPlas,#8482; shielded
    Baffle: Low diffraction, IsoPower™
    Port: FreeFlow™ flared
    Network: Straight-Line Signal Path™ (SSP)
    Terminals: Gold-plated, 5-way binding posts, bi-wirable
    Dimensions (H x W x D): 1067mm x 311mm x 368mm
    Weight Per Speaker: 55 lb/25kg
