Charan said:
Dear All,
Has any one actualy bought/used the new JBL DSC 1000???
If so - i would be very grateful to receive your reviews of the system and also whether the DVD player can be made codefree/multiregion?
Many thanks and kind regards
Charan
I have been using the Jbl Dsc 1000 for a few months now.
Cd playback is good once you set the subwoofer level correctly (for prologicII: 5 small increments above half level at the back of the sub for my 12 by 12 room). Dolby Digital sounds excellent. Video playback is great. Treble is sweet as compared to Sony and Panasonic all in ones. Distortion is minimal when new but after the break-in is audible near half volume and above. Midrange is tight and the bass is sufficient for my small room (100watt powered sub).
I am no audiophile and am comparing the Dsc 1000 to Panasonic, JVC and Sony systems. I haven't played DVD-A on it yet. CD playback sounds similar to a Yamaha system of one of my friends. It sounds best around 25%-40% volume. The sound is never harsh on good recordings. The remote, however has white print on grey background making it difficult to read.
The s/n ratio is only 80, but it sounds much better than the JVCs (S/N 96) and Sony systems I had before. It does not have dvi or hdmi inputs/outputs but it claims to do PAL progressive through component out. The picture can be fine-tuned through the controls and test screen but there is no auto-color option (available on high-end players). The colors are vivid and shadows have good detail (10bit/27Mhz dacs).
On some old cd recordings the sub lacks detail, but dolby digital is always spot on. MP3 and WMA playback is only 2-channel, prologicII works for cd, slightly improving the sound. The speakers can be set to the nearest foot (delay).
I haven't listened to the Onkyo all in ones yet and maybe you would like to compare it to them. I personally like the sound of JBL, Infiniti and Yamaha speakers.
I haven't dicsovered a way to make it multi-region.
I would give this Jbl 9.5/10 - Highly recommended.
